I've noticed two different mechanical noises that occur long after the engine has been turned off, like 45 minutes to an hour after shutdown. The noises only occur occasionally, or maybe I'm only occasionally close enough to the car to hear them.
The first noise is a whirring sound from the underside behind the right rear wheel that goes on for 30 - 60 secs or more. Its a whirr with a sort of "pop" at the end: "whirrrrrrrrrrrr-pop".
The second noise is a rapid clicking from the engine bay that goes on for 20-30 secs. It's sort of like the sound made by those little plastic wind-up toys. Dunno... it's hard to explain.
Lastly, these noises don't happen together. I never hear them both on the same day, and I only hear either of them intermittently. I haven't had a chance to locate the exact source in either case.
Anyone else notice these sounds, or know if they are normal? If they occurred shortly after engine shutdown I wouldn't think twice about them, but 45 minutes later?
Thanks!
Thanks!
