My boost gauge is reading -7 vac which is extremely low, usually run around -20-22 vac. i took off the line to the WGA and then plugged that hole as soon as i did this the vac went to normal. Would a bad WGA cause this? My boost stays at 6psi when i boost and idling is fine no cel. I tried to see if i could blow through the WGA lightly and i could so my diaphragm is bad from what ive read, but ive never heard nething on here about that causing a low vac reading. If i could get your input much appreciated i dont want to spend money and time on a WGA and not need one. Thanks
