Can I just copy and paste this script into a notepad file and call it a day?
I would download the Apply Tweaks.zip file and extract it directly into a USB drive formatted to FAT32.
Why take the risk?
Why take the risk?
This is the correct way to do it.
This is probably a stupid question, but can this firmware update be applied to the 2013 CX-5 system?
The V.55 update went fine, but I can't get the tweaks file to work. I copied the .txt file to a FAT32 formatted USB stick and then renamed it tweaks.sh. I plugged it in and the light on the USB drive blinked for a few seconds, but nothing else seemed to happen. I still can't use the touch screen while the car is moving. What have I missed?
First of all you need to give it some time. It takes about 5 minutes before the message comes up "tweaks applied". Did you get this message? If so, did you reboot the system after the tweaks were applied?
If you have to do it again, I'd suggest doing a full format of your USB drive vs a quick format and then do it exactly as I described in #21.
I renamed the file on an OSX machine, but did the format on a Windows computer. I never saw a message "tweaks applied". Where does it appear? I think the nav screen was on when I drove for about 15 minutes after inserting the USB drive. Should I insert the drive after the car is running or before I start it? How do you reboot?
Thanks.
