Update on my 626
Sleeper626
1991 Mazda 626 DX
i post here often but i have done some things and have put a few things on my 626.
here are some more pics. yes that is a real deal mazdaspeed bar and i was test fitting the wheels but its rubbing on the rear struts.
Cool sleeper project you've got going there...:D
What's next on the list after you sort out the rims?
Can you use a spacer to fix this rub.....This model 626 looks really good with the 17s....Nice old-school ride.
Anthony
im getting maybe(crosses fingers) a 89 MX6 GT and going to swap the turbo motor and some intetior and other things. we will see what happens and i will post up.
Anthony
i think its going to take spacers but i want to get the right tire size and see what happens. i test fitted them with the stock 3 tires,205-50-17 and i need 205-45-17. i hope they will clear but i think they will need spacers.
i have also added a auto down master window switch from a early 929 and it had a door lock switch that i am going to wire up. i have added energy suspenion sway bar endlinks front and rear and i had some rust holes in my spare tire well and i had that repaired and i got the windows tinted and swapped front dual piston calipers from a 96 subaru legacy and replaced the rear discs and replaced all the pads.
