Update front headlight from basic to high spec version? 2023-2024 CX-5
Hello friends, I hope you are well. Could someone give me some guidance? I have a Mazda CX 5 Active South American version that comes with basic headlights without daytime running lights. However, I bought a used original headlight and it is all LED with daytime running light. But when I installed it I realized that it flashes too fast when I turn on the turn signal of the headlight that I replaced, can it be solved with a relay or resistor?
I would like to know if this adaptation is possible or if not, not spend more and not buy the other headlight.
Thank you very much and blessings to all.
Before
After
It needs one or more resisters. You will have to do some research the difference between new and old bulbs currant draw to size a resister.
its coding in the icm module if I recall but not many people know how. So best bet add resistors
