Here is a copy of the reply I sent to Jack with some of your questions -
Jack,
Thank you for responding so quickly. You have answered all of my
questions, but may I ask you to answer some others?
Currently I am a member of
www.msprotege.com , the largest Mazda Protege and Mazdaspeed Protege community on the internet. I relayed your message to my fellow forum members about the project and have gotten a very positive response. You can actually read the entire thread here -
http://www.msprotege.com/forum/showthread.php?t=61306&page=1&pp=15.
It seems as though many people have more questions than even I did, which is no suprise since many people don't know much about your product. I know you are a busy man and have a company to run, but I would like to know if I could get some more information for others in my community, as the idea of a PnP unit for the Protege has been a dream for all ever since the car has been released.
Most of the people have been getting their information about this unit
through Corksport and their website. If you would bare with me for a moment I would like to rely some questions from fellow Mazdaspeed owners. If it is
alright with you, you could just reply to me and I will relay the information
to the board or you or one of your employees could register and answer their
questions.
A PnP unit that works on the Protege would be a VERY lucrative part of
the market for your company and I would like to see this go over well in the
community just as you would.
Here are some questions sir:
1.Switch between two pre set map settings with included switch.( Whats this switch all about, can someone explain more?)
2.Specifically set/tuned to work with Cork Sport 'Power Series' product line
(exhaust, intake, etc). Can be reprogrammed at a later time (by specified
outlets). (I have a custom 2.5" catback and an apex d/p on the way so do I tell them that when I order? I guess what am trying to ask is how do you order it?)
3.In an old thread someone said that the unichip ups the boost 3 PSI over
stock. So does that means that the boost is set to 9.5 PSI from 6.5 PSI
stock??. One last bit that conserns me. If the Unit Chip controls boost then
how can it be 100% PnP? You would still have to tap the wastegate line right?
4. I'd be concerned about pinging with this thing on there. Will this be an
issue?
5.How much for the reprogramming for the exhaust and other mods after you get the pnp for a stock Mazdaspeed?
6.Will it control my 460cc injectors?
7.I do wish I knew if that dyno chart was with the boost @ 9 PSI or not.
That is all I have for now sir. Thank you for the quick response and hopefully
yourself and I can make this a reality for more Protege owners.
Ben
