liquidflem
- MS3
Guys,
I have a new 2010 RX8.
I'm not sure if this is normal or not, but i changed my oil for the first time since i bought the car, at 2000 miles and was only able to get 4 quarts or so out of the car after letting it sit and drain for about 15 minutes.
I noticed the drain plug is at the front of the oil sump and i'm sure that this has something to do with it. I put the front of the car on jack stands at their lowest setting as I don't have way to change the oil while allowing the car to be completely level.
Do you guys know of a better method besides draining and filling the oil twice (after running the motor for a couple minutes to circulate the first fill of oil through the lines and cooler)?
thanks!
thanks!
