they are not in plastic and you will have the choice of buying the kit with bushing or without.mazspd6 said:I take it this will be compatible with the bushing kit that TWM also sells, I just ordered it yesterday and I am looking forward to the short shifter as well!!
The bushings used in the "bushing kit" look like aluminum and these look to be plastic...I just want to make sure what bushings will be in the kit so when I purchase the short shifter I won't have two sets of bushings that are the same.
If you get a chance to check on these questions with 'em that would be good.
Thanks.
MS6freek said:they are not in plastic and you will have the choice of buying the kit with bushing or without.
Klip said:MS6freek, sounds good but did you loose any of the smoothness shifting from gear to gear? any notchiness?
My son has a short shifter in his M3 and while the throws are really short it a very notchy feeling, not smooth at all changing gears.
Just curious, I've never had a short shifter, so I don't have a clue.
And what exactly is the difference between buying this item with and without the bushings?
Rawyzf said:pics indeed!
