Turn to Fast = Shut off
Might be rust or something in the fuel tank that gets kicked up and clogs the fuel pump when you turn too fast.
thats what i was thinking. i know second gen's rx7's shut off if you turn to fast and the baffles are rusted out or the sock (is that the word?) gets clogged
I don't have the problem on mine, but I would start with some injector cleaner fuel additive / Seafoam.
Ok I guess I'm gonna try the Injector Cleaner and if that dont work I'll get some better injectors. Thanks
why would it be the injectors? if there is crap in the fuel rail injector cleaner is not going to clean it out.
i'd start with checking the fuel pump sock if you strongly believe it's a fueling issue.
does the car hesitate or just drop revs?
also is this dependent on right or left hand turns?
ok.Yeah the car does hesitate a little and ive only had it happen when i make a left hand turn.
Well I found out yesterday its not just when I turn because it happened as i was pulling away from a stop light.
Check the fuel pump. Does it only happen on a low tank, or does it happen even when the tank is full?
Check your battery connections first...might be loose and that can cause the problem...
...and how many miles on the original fuel pump filter/sock?
Fuel pump relay would do that too....pull it out and test or replace....
Hope that helps....
