TurboXS type S install help!?
Rally Ninja
MSP
I Just bought a type S BOV but it didn't come with any instructions. I can't figure out where the 5 washers go. Also theres 2 different pipe things that fit at the bottom of the BOV? which one do i use?
Mine works best with no washers at all...just perfect. I'm not sure about the two different pipe things without seeing them. Mine was on the car when I got it, and the bottom of it is inserted into some type stiff hose that is in turn clamped onto the nipple on the upper IC pipe. I don't recirculate. Attached is a pic that should clarify.
On the Injen, I assume? I cut mine off (but left about 1.25" for a nipple), then filled the hole with silicone. Worked great, and I can unplug it and tie onto it if I ever want to recirc.
Ok i have it hooked up. How many washers did you put in it? Are you having problems with stalling? cause mine is. its about 500rpm at idle eeeek. The BOV is slow to close and I'm guessing thats why it stalls. I have 3 washers right now Just trying to figure out the right amount.
