builthatch
Anyone still have this on their car? If so, what are your reviews now that you've had them for awhile?
i still have mine. works just as it did when first installed. holds boost fine, no leaking; boost logs are the same from about two weeks after i installed it to now.
i did take it apart about a week ago and cleaned the inside, the spring, the washers and the piston. took about 2 minutes. i also applied a very very light coating of silicone grease, very high quality grease, to the piston.
