Sure, but it would be ugly looking.LAZERBLU2003.5 said:would having the steel pipes ceramic coated inside and out help keep the air cooler than having them chromed?
byohndspeed said:ok so you got 130ish on your steel pipes, and 108ish on the aluminum. what gauge are you guys using? the reason i askes is that on the test car for my hardpipes we ar eusing an autometer intake temp gauge and we only ever seen 120 with ours before we wraped them..we saw alittle more out of the stock pipes than you did, and we were running 10psi also...where did you put the probe? i'm not trying to be rude, just trying to figure some things out..
Riles said:How will these pipes compare in price and quality to the new $200 powdercoated steel pipes that DSMConvert sells?
