Turbohoses R&D Affordable Hardpipes
ok so you got 130ish on your steel pipes, and 108ish on the aluminum. what gauge are you guys using? the reason i askes is that on the test car for my hardpipes we ar eusing an autometer intake temp gauge and we only ever seen 120 with ours before we wraped them..we saw alittle more out of the stock pipes than you did, and we were running 10psi also...where did you put the probe? i'm not trying to be rude, just trying to figure some things out..
Unfortunately, this is information that I can not supply you. Our products, design, materials, engineering etc... are all proprietory information. However, the gauge of the metal is fairly thin, hopefully that helps.
We do not use aftermarket temp. gauges as they are sometimes not consistant with readings from other methods which are more conducive to aquiring more accurate results.
As you already know, we can not really compare data accurately. Being two different vehicles, temperatures, dynos and research methology will always net two absolutely different results.
Turbohoses R&D
How will these pipes compare in price and quality to the new $200 powdercoated steel pipes that DSMConvert sells?
Our pipes our more expensive.
We have not seen any of our competitors piping, so it is impossible for us to comment on fitament and/or quality.
We MFG. parts for many of the larger well know aftermarket companies. Our company is ISO9000 compliant, which bascially means that we meet a standard of consistency in production, quality control and proper storage of raw materials.
However, we pride ourselves on not only our products but service as well. You can phone us 9:00 PST to 4:00 PST M-F and our customer service agents will be available to assist you.
Turbohoses R&D
