or you could upgrade the engine management to fuel and ignition...instead of the fuel only control that comes with the hiboost kit...it is an optional upgrade from hiboost.
Only because you own a MSP? The question at hand is a MP3 owner. Will his MP3 clutch hold up to "said" numbers?
Correct me if i'm wrong but doesn't the MP3 already come with one of the "V's deleted= VTCS or VICS...so swapping the ECUs for a regular protege or P5 may not work....
it can be fixed with proper electrical know-how. you'll need to get a VTCS solenoid and hook it up straight to the ECU at pin 73 for one terminal and hook up the other terminal by splicing to the wires coming off of pin 97 or 71... this can all be done with a few inches of 16 gauge wire by the ECU and the VTCS solenoid can be hidden there... you really must have the wiring diagrams and skill to do this... otherwise have someone do it
hiboost kits come with the haltech f10x, which only controls fuel...they have an option to upgrade to a haltech e6x which controls fuel and timing. jared which kit did you order? i would suggest trying to upgrade the ems to the e6x straight from hiboost if you still can.. if you just got the budget version-the version without engine management or blowoff valve, i would look into getting the mcrotech..from what i have read it is the most tunable one for the protege.
hell the stock clutch holds up fine to decent numbers.
Replacing all your vac lines with silicon ones is always a good idea though not necessary
I guess I will find out if i need a new clutch when it starts to slips....
Is there like a " full sillicon hose kit" for the Protege that I can get all vac lines in one pack????![]()
is it not the same clutch? i was under the impression that the mazdaspeed models did not have any sort of upgraded clutch.
I heard of people putting in a MSP ECU seeing it was programed for a turbo set up. I'd search that first.
I wouldnt trade that MP3 ECU straight up though.. it's worth way more then a stock.
