I'm interested in what can be done to our engines to make them flow better, and trying to figure out how cheaply it can be done.
Right now I'm trying to find out more about cams, and maybe some headwork while I'm at it.
Are the stock cams really suited for FI applications at all? What sort of properties do you look for in a cam for turbo applications. Lift, duration, overlap, etc?
I saw a thread about a jspec intake cam, but it looked like they were made more for NA applications, and I didn't know if MSP's would benefit from them.
Also, it was mentioned that you could get a blank cam and get it custom ground by crower. Has anyone done this? Do you have to give them all the specs, or do they figure out what will work good for you? Any idea what this would cost?
What kind of gains could be expected from some custom, optimal cams on our engines(intake or exhaust or both)? Would this be a cheap mod in terms of horsepower/money?
Would new springs or anything else be necessary? How much would those run?
I like the idea of making the most out of a lower amount of boost, and hopefully keeping some reliability by giving better flow instead of just upping the boost for more power.
As far as headwork, anyone know where I could get this done? And how much I should expect to pay for a spare head? How much does extrude honing usually cost? Anyone that has gotten their head ported care to chime in?
Any other suggestions for engine tweaks along these lines?
