TSC / DSC Light
Mazda 3 Sport
Hi
This light has appeared on my Mazda 3 Sport. I have tried turning the steering wheel etc not sure what it could be. Can any one help????
Hi
Yeah Ive tried that. Also tried turning the steering wheel to full lock then turning it the other way. Just lost to what it could be.
There's possibly a failure in the electronics or wiring for this. There are miles of wiring just for this system alone. Very hard to troubleshoot. So, you're seeing The TC light (car with squiggly lines) and a DSC light (DSC alone) NOT "DSC off"? The DSC and TC lights should NEVER illuminate unless the system activates. This indicates a failure in the DSC system. Check all fuses. Check all plugs in the steering column. Check brake fluid level. Then you're kind of stuck with the dealer, without serious diagnostic tools and talents.
Not too sure if this is the same thing but when I got my stereo done on my car, the idiots blew a fuse which caused that light to come on. This of course was on a Honda Civic SI so it may not be the same in a speed.
