L0w_N_sl0w
- Mazda,Protege5
I have an 03 Protege5 manual transmission.
Recent work done:
-Motor rebuild
-All new mounts motor and Trans.
-Flywheel
-Clutch
-Drive axles
-New clutch fluid
Issue:
Experiancing harder then normal shifting. Scratches going into all gears when car has been sitting.
I was thinking about replacing the fluid again with redline or amsoil gear oil to see if the problem continues.
Even when the car is running but not moving the shifter seems stiff putting in gear. It even feels notchy in the neutral position.
I had zero issues with shifting prior to the work being done.
Please help thanks!
Recent work done:
-Motor rebuild
-Flywheel
-Clutch
-Drive axles
-New clutch fluid
Issue:
Please help thanks!
