I have a 2003.5 MSP and about two weeks ago I had to take it in for what I thought was a clutch problem. Turns out, and this is what -he- said, a ring gear broke on the final drive carrier of the transmission...? I know close to nothing about transmissions so excuse me. The mechanic said the whole entire ring needs to be replaced when this happens and that when he called Mazda for the parts, the guy knew exactly the problem because it's a "common mishap with this vehicle". Though searching around the internet, I couldn't find that that was valid.
Anyways my main question would be, I happen to come across a regular Protege transmission for much less of a cost than the 1,800 it would take to rebuild this ring. So is it possible to use a regular protege transmission in a Mazdaspeed protege?
