They have about the same life, depending on your style of driving.
The trans fluid must be replaced due to contamination not fluid degradation.
contamination from what?
No. (ugh)if i change my trans fluid will stop the clutch slippage?
While you're changing your trans fluid, try to wipe the magnet clean as the metal particles will stick to it while the old trans fluid is draining.
I ran Pennzoil synchromesh for a while, but drained it when I talked with a guy who talked with one of Pennzoil's engineers, and he said that it was not at all recommended for our transmissions. For what that's worth.
