tpms sensors
thanks i had a flat this weekend and no lights and no sound. called Mazda and they said not all model had it in 08. i'm not sure if that right or not they said if the valves where plastic then no tpms if they where metal then they where Tpms. also rotated the tires and nothing happen.
I just checked my owner's manual, and it says "TPMS (*some models)", so you may not have it. I have a GT which does have TPMS. What model do you have?
I have the GT also
Then you should have TPMS.
When you turn your ignition to on you should see the TPMS warning light displayed on your gauges.
In my case, my CX9 doesn't have TPMS ... could be easy to install them? Could be only but the tire sensors? Or there is another kinf of sensor?
