Towing - Kendon Single Ride Up Motorcycle Trailer
2019 Cx5 2.5T
Has any one towed an approx 450 lb motorcycle using a Kendon Single Ride Up Motorcycle Trailer (approx 300 lb)?
TIA
I have a 21 GT non-turbo I pull a 6 foot wide by 10 foot long trailer approximately 900 pounds plus a Harley bagger approximately 850 pounds no problem
Given I have aftermarket tires that are approximately 0.669 in closer to my whee wells: Have you noticed any sag? Do you use helper airbags?
I did not notice any sag. If the trailer is properly loaded there shouldn't be much weight put on the hitch.
