Tire Rotation Poll How do you rotate your tires?
  • Rotate tires at every oil change.
    Votes: 15 42.9%
  • Rotate tires on a independant mileage schedule.
    Votes: 14 40.0%
  • Rotate tires as needed by measured tread wear.
    Votes: 4 11.4%
  • Never rotate the tires
    Votes: 2 5.7%
  • Total voters
    35
Forward cross at 7-8,000 miles or if wear is measured to be different by 3/32 inch. FWD. I would do 5k if AWD. ED
Can anyone explain the functional difference between the forward cross and rearward cross patterns?(uhm)
When I go to my Dealer for an oil change; they rotate the tires too, cost $86.95 with the Mazda coupon. (4 Qts Oil, Mazda Filter, tires, inspection etc..)
4 quarts of oil? You do know that these cars take closer to 5 quarts (4.8 quarts to be exact but I dump in 5) than 4 right?
The forward cross is preferred because you don't need to do 3 rotations to get the tires tread equalized. This assumes that the right front will normally get the most wear.
Yes correct I miss typed 4qts. Just to be different. :). Yes the dealer will put in (hope) the correct amount... LOL...
Hope for the best prepare for the worst. It's good advise to check your dealer's work.
Latest posts
