I never rebalance unless there is vibration problem. Ed
..assuming your alignment doesn't go out.I too change out my tires at home, swapping my winters to summer. So while the unused set is lying in the garage, I bring them to the tire shop for a balance, which is a free service from the original purchase. Always freshly balanced ready to go for the next swap. We typically drive 15,000 kms per year, so twice a year is probably overkill, but at least we should get good wear of the the rubber.
What size wheels are you running your snow tires on?I too change out my tires at home, swapping my winters to summer. So while the unused set is lying in the garage, I bring them to the tire shop for a balance, which is a free service from the original purchase. Always freshly balanced ready to go for the next swap. We typically drive 15,000 kms per year, so twice a year is probably overkill, but at least we should get good wear of the the rubber.
Yes, mine also says 5K-mile schedule for tire rotation. The build-in "Maintenance Monitor" app also says 5K-mile tire rotation schedule.10k?
Mazda service schedule says 5k
