Tire PSI
RHAGEL
Contributor
06' 3 Touring
I was just curious to see how people fill their tires. I have stock 17 Goodyear RSA's. The recommended pressure is 32. I fill mine to 35. I found that I:
1. Get better gas mileage
2. Less body roll
3. Better steering response
4. Better tire wear
5. No noticeable degrade in ride quality
Other that the fact that they want your tires to wear out quicker, grip would be the only reason to fill them to the reccomended pressure. I wouldn't actually know since have never tested max grip in the car.
I just want to see if anyone else has any insight.
i need to get mine checked out and filled correctly. i have like 20-25 psi on front tires and right rear is like 13 psi (lmao) and other side like like in the high 20's. so 35 psi is a good rate for all four tires? i want better gas mileage and good tire wear.
dear lord 13psi... is that a drag slick?
i ran 36psi all around when i had the rsa found 34 seems good on the 18" runnin with kumho mx road noise is quite loud but the grip is much improved
tires leak air on its on,
its a good practice to check ur tire pressure once a week.
I do mine monthly cause im lazy.
during the summer, I ran 32psi on cold tires (17'' RS-As).
I tried 35, ride got to bouncy. I'll try it this coming summer since the suspension is more worn now.
winter I ran 40psi on warm tires (not cold), at 7 degrees C.
I need to check it again since its -10 degrees C now.
please note: psi will increase with increase of temperature, and vice versa. also note the max psi stated on your tire's side wall.
Sry, couldn't help but laugh out loud at the 13 Psi...
32 is good if you're not sure if going with higher will affect your tire wear.
Couple things:
-Fill your tires when they're cold - driven less than 2 km. Best to do right in the morning after the car has sat overnight.
-General rule is 10 degree temperature drop = 1 psi pressure drop.
So if you filled your tires in the summer at 32, and it's winter now (like -30 C last week for me) then you can easily find yourself at 26 Psi and lower.
Check every week as someone above mentioned, but if you even check once every 2 weeks or month, you're still probably fine. Takes 2 seconds to put a guage from your glove box onto the tire. I usually just check one tire if I'm just trying to get an idea of what my pressure is b/c I'm lazy too =)
I put 36 PSI on my winters to see how it would go on a -15 C day thinking that the weather was gonna stay cold. It has warmed up to about -5 C and seeing this thread has made me realize I'm probably over inflated...
As for gas mileage, I did see a bit of improvement. Ever since we had snow, my gas mileage has visibly been declining according to the trip computer. I went from 9.1 L/100KM (Cdn, below the 9.2 avg) to now at 9.6. But it hasn't moved since I inflated my tires to a higher Psi. So my decrease is probably due to the fact that I was trying to keep 32 Psi and also b/c I have my heater on all the time (I heard if you have it on the floor setting and anything to the right, it uses the A/C automatically? I heard this for the 05, is this true for 06 M3?)
I was told that using or filling tires with Nitrogen mixed air from tire centers would prevent air loss (or slow down the process). I just keep my tires inflated to specs. When I buy new tires, I would look into places that fill it with nitro.
yeah its true if you use your heat at the floor (12'o clock) or to the right it automaticaly uses the ac... so your loss in milleage could be accounted for there i would think
If the company recomends 32, it's more than likely better to use that. The traction diferences are noticable between the two... Ye don't want to look like an ass trying to save $12.00 a year in gas, just to smack the back of a guy on a mortorcycle and accumulate $1,000000 in Hospital bills?
Traction and grip is not an issue unless you are pushing the car to its full potential. I have been slightly overinflating my tires for years with no problems. I drive a windy mountain road everyday and don't even get my tires to squeal. I agree though, if you are making turns at 60, then you may want to rethink that. But then again, if you are making turns at 60, your traffic tickets will be outrageous.
The reason why is that nitrogen particles are larger than air particles, so then don't leak through the tires as easy. Not only that, but nitrogen is lighter than air and does not condensate so you wheels will be lighter, (maybe a pound or so). I do know that Costco uses nitrogen in their tire department.
Air is 79-80% nitrogen, most of the rest is oxygen, then a small amount C, H, and O compounds, so nitrogen isn't really bigger than air particles. Nitrogen fill is drier, as you mentioned, which helps reduce expansion. Their is some talk of better tire life without the oxygen on the inside, i think this is mostly for car who get the tires pretty hot for extended time periods, like road course driving. I would use nitrogen if it was easily available around me, but I haven't found an easy source.
Oh, and I tend to run higher tire PSI than 32 on the street.
Yeah - Mazda 3's manufacturer recommended PSI is 32. I have been trying to keep that, but when the temp went down 20-25 degrees here in Canada, my PSI went down with it. So I overinflated a bit as an experimentation and also in anticipation for the cold weather.
Well this week it was warm, around 0 degrees C. I checked my tire yesterday finally(been lazy) and it was at a ridiculous 40 PSI. I thought that a bit of air would have leaked out and maybe I would be sitting at 36, 38 tops. So I of course let the air out until I was back down to 34 PSI. So that goes to show that you should probably check your pressure every week especially if your weather is tempermental like here in Edmonton.
PS. I don't know why you think inflating a little past 32 would cause my car to lose control and kill someone? That's absurd unless I somehow go past the 44 PSI rating on the tire and it blows up.
Wow, did Costco ever do a sales pitch on you! LOL :)
Air is 78% Nitrogen, so, the "particle size" is pretty much going to be the same. So, from that, you can figure your tires are not going to be any "lighter" either (1 lb lighter? How much do you think the air in your tires weighs?)
The only benifit to using Nitrogen over air is that pure nitrogen has no MOISTURE in it, which can affect the longevity of the tire (but who keeps tires for 10 years anyways) and how much the tire pressure increases as the tire goes above the boiling point of water (100 deg C). No water in the nitrogen, so the pressure does not increase quite as much (only makes a 2 or 3 pound diff) (We use nitrogen in race cars because we need extremely stable tire pressures mainly in the 170-240 deg F range where water content makes the biggest diff, almost nobody in a street car ever gets their tires this hot unless they are out of balance) Although, if you use completely dry air (which can be purchased) it is pretty much the same as using nitrogen. Or, just fill up your tires on a very low humidity day for free.
A side note about tire pressures. The size of your contact patch is directly related to tire pressure. Double the pressure, and you cut the size of your contact patch in half. Therefor, if you increase your tire pressure over stock, you are reducing the contact patch, and therefor you are reducing the amount of traction the car has. And when it comes to an emergency panic stop, every square mm of contact patch matters. Plus, any savings from fuel economy you get from running an overinflated tire are greatly offset by increased tire costs because the center portion of the tire will wear out a lot faster...hmm..... get an extra 20 miles to a tank and buy a $800 set of tires twice as often....good savings (doh)
I have learned a lot about tire pressures first from being a class "A" technician, but also from racing, where every 0.5 PSI difference can make a huge difference to tire longevity, cornering ability, braking traction and tire temps.
Guys...
go outside, open your drivers side door, and look at the sticker titled "Tire and Loading Information". It will tell you what is recommended ;)
It's in your door jam.
I hope you feel a little better about yourself trying to be Mr. ******* Smart Ass. You basically re-iterated everything I said. I have never bought tires from Costco, I just said that I know they use nitrogen. And I also, said that I realized that over inflated tires can reduced grip but I havent seen any adverse effects for over inlating 2 psi. And so what if your tires are 1 lb. lighter? I was just noting that it "might" be a positive. So next time shut your ******* mouth (figuratively speaking) and stop trying to make yourself look better by putting other people down...jackoff.
Actually, I was correcting some of the missinformation you were spreading.
I'm not sure why you have the need to mention this, but, um, OK.
RHAGEL said:
I just said that I know they use nitrogen. And I also, said that I realized that over inflated tires can reduced grip but I havent seen any adverse effects for over inlating 2 psi. And so what if your tires are 1 lb. lighter? I was just noting that it "might" be a positive. .
Please re-read what I wrote, and you will see why it is impossible to make your tires any lighter by using nitrogen.
Wow, somebody pissed in your cornflakes this morning eh?
I am just trying to put an end to some of the misinformation in this thread. There seems to be lots.
You asked for comments.......just because they don't agree with what you said, don't get all pissy.
I'm just tired of all the people always making smart ass, know it all comments. If you have a comment, make it. Just don't put people down because you think know something that others may not. This was never meant to be about nitrogen. I had a comment to make about tire pressure that is legitiment and was trying to spark some new conversation. Thats it, maybe I overreacted a bit...my apologies.
Hey, NP. Well, you really got some conversation going....:)
