DurhamProPhoto
- Mazda 3 & CX5
I am a little puzzled about something. My Mz5 has a
sticker that says the tires should be inflated to 34PSI.
The tires themselves say that they should be inflated
to 44PSI Max. Which should I be following? My wifes
Mz3 Sport is running the exact same tires and her sticker
says they should be inflated to 32PSI not 44.
Running at 32/34 the car does hug the road better and
the ride is smoother but, If I run the tires at a lower PSI
do I not cause edge wear?
Is there any other reason I would not follow the tire
manufacturers numbers?
Cheers,
Robin
Cheers,
Robin
