Eric-BlackMSP
- '03 Black Mica Mazdaspeed Protege
I'm making this thread in response to all the posts about popped motors etc lately on the forums. I'm by no means an expert at this subject. I just gathered a lot of info from the other threads and I'm posting it here in a central area for all to see.
Lately, past few weeks, a couple of members have been popping thier motors due to increased boost(and other things). We can debate all night and all day as to what caused the motor to go, but lets just try to help each other with some tips to run higher boost safely.
First off, if you want to run higher psi, I would recommend at least 93 octane, and then adding in some Toluene(SP?). You pick this up at a paint store, and it should be used 1 gal per tank of gas. It is 100% safe, and it is naturally occuring in pump gas. This will act as the first barrier to detination, and hoping save some motors.
Second, if you are running a CAI and FMIC, please disconnect your FCD. The fuel cut will actually save your motor, as it stop you from running the car too hard with too much air etc.(My understanding, but please comment)
Third, do not push your car while your in 4th and 5th gear. This basically means stay out of boost in 4th and 5th, or return to stock settings. 4th and 5th gears put high strain on the rods and internals already, with the added psi you are asking for problems.
Fourth,run colder plugs, the NGK are what most of us use. This will also help prevent detination.
Fifth,if you are using a MBC be mindfull of boost spiking. I would recommend a EBC, but they can be exspensive.
Well thats all I have, please free to add and comment on your own experiences! I'm not an expert, and all help is great!
Also please note, that every car is different, and to take all information given to you with a grain of salt. Thanks guys, and happy boosting.
-Eric
-Eric
