Throttle body hose connections?
winordieracin
2002 Mazda Protege ES
If your looking at the front of the car there is a hose that comes off of the bottom of the throttle body, can anyone advise me on what that hose connects to? Thanks
Correction there actually coming off the intake manifold right where the throttle body fits into place.
Ok so maybe thats what I have wrong, so if that connection is for coolant, where does the coolant overflow hose connect to?
There are two hoses that should be attached to the bottom of the throttle body itself, those are for coolant as mentioned. As for other hoses in that area, if anything they are vacuum lines. I am not positive about the 2.0 but the 1.6 doesnt really have anything else near the throttle body on the underside.
Okay, im gettin closer, not those two hoses for coolant on the throttle body where do they connect just so I can make sure there in the right spot? Thanks
