those bastards! they stole my hood!
it doesn't fit good at all, and your nozzel holes are at least the right size.. LOL i had to use washers on the pass side to raise it and new washer nozzles
EDIT: i put 2 washers on 1 side and pounded the latch thing to the driverside, and that makes all the diffrence, now it fits perfect, cept for the washer holes but i fixed that already
No, my nozzle holes were way big as well. We used silicone to stick them on. I got washers and we even expanded the hood hinge holes to allow a bit of play. Also moved the latch around.
edit: Anyways..I'm not too worried bout it. Hood doesn't flap that much. If so, I'll just get some hood pins. Tested it going around 160-170kph in the crowsnest pass. Pretty windy and it was ok. the glue on the nozzles even held up. :)
the mesh i don't really wanna remove as the grill behind it is smashed to bits, chunks missing everywhere from rocks and s***
so what you doin' with your stock hood after you take off the decals
mine's a little mashed up.. looking for a new one
I think he's gonna keep it for the winter.
he can have mine... no need to look good in the winter.. in calgary, you'll be covered in snow, anyways.
sorry im mentally attached to my stock hood, parting with it would be a disaster!! but you can have my passengerside fender!!! its a little busted up but it will still fit
