princess peach
- '92 Miata, '06 MS6
agreed, the food is good but I don't think it deserves all that hype. Waiting times are ridiculous, even for takeout
That close to the Hall Of Fame?
Snell rating is a must. Some local Autocross events will let you get away with m rated helmets. I prefer to be safe and go with what is accepted at all events which are the SA helmets. Depending on whether it is 2005 or 2010, it will be good until either 2015 or 2020. I wouldn't cheap out on a helmet. Snell has an explanation of all tests carried out on helmets to gain the certification as well as a full list on their website.
^^^ Yeah, I sent Ivan a text yesterday that it sucks we're finally coming to Toledo and you're car will be down... I hope she's back together by then. You've got time.![]()
Well I went over to my friends house where the MSP is tore apart and looks like I'm going to have to either get a new crank or get this one turned down. I tried fitting the other good bearings in that cylinder position and they have just a hair of play. They might not knock at first, but after a good autoX it would be another tear down. So I probably won't have her ready for the 3rd, but for our little August weekend meet/race at the TEA she should be good to go. I'm replacing all the bottom end bearing, piston rings, timing belt, tension motor mounts, and all the gaskets. I'm going to port the intake and turbo while they are off and do a little wire tuck(maybe) for the top of the motor. Good thing I picked up a 2nd job. I'll either be running my friends
new Fusion Sport AWD or the 2 in SM. Good times.
