princess peach
 - '92 Miata, '06 MS6
You could also be over-thinking things and worrying that something's up... I've done that a number of times.
ditto
Seems EVERYONE is ALWAYS talking about rear sways around here.
What happens in a FWD car if you push it too hard? Like how RWD's spin out and whatnot.
What's understeer? I've heard the term, but can't say that I know what it feels like.
Again though, what's the "worse case" scenario in a FWD car when pushed past it's limit? What happens when you take a turn WAY too fast? Does it spin out too? Or does the front end just slide?
Ah! Gotcha
you should come to Nelsons and/or Beave run and ride with someone, get a feel for it.
With a normal suspension, its not that bad. The front will normally push out.
With a full race suspension on a FWD car the rear will spin out if you: lift off the throttle in a corner, brake too far into a corner, don't get on the gas fast enough in a corner, turn the steering wheel too quickly, etc.
Pablo's done it...
hell, big rear bar and a sharp corner on the street can land you looking the other direction. I've done it... Pablo's done it...
