Menchies tomorrow?
Yep! Hopefully it doesn't rain again...
Dave and I are running up to Will's for a drug deal then will be back in time for Menchies.
Menchies tomorrow?
John that would be sick to be a lab rat for corksports new products
Yeah I mean I don't have racing seats so idk if I would benefit from the 5 point harness
I do have to say... If we're dreaming, I've always wanted to take my father in laws MG midget and put the V8 from the radical roadsters (up to 520hp N/A & only weighs in at 202lbs) in it. That along with a couple of small turbos would make for a hell of a fun DD. Considering the MG block & head are cast iron, the weight probably would stay much the same but with a heavier 6spd sequential gear box the weight distribution would move more aft to provide a better balanced car.
Without the proper routing holes in the seat back and thru the bottom of the seat for the submarine belt, they won't provide any real safety benefit.
(potkettle lulz
I would be interested in 5 points for the Fatty if John is talking about making harness bars. I know you mean for the Pu but maybe we can work something out for the MS6?
You don’t NEED racing seats to benefit from a harness. Proper belts go a long way.Yeah I mean I don't have racing seats so idk if I would benefit from the 5 point harness
I'm thinking about it. Working on getting a powder coating outfit first.John, Patrick, did I miss a post somewhere? John, are you making harness bars or something?
You can route a harness in between the head rest posts. These posts are strong enough to take the side loading. You can also do the same with a Y style harness. As far as an anti-submarine belt- You should never use one with a set that isn't designed for it. Anything that can hold you in your seat more firmly can provide a safety benefit as well as a performance benefit due to not needing to exert as much energy by holding on to the wheel and bracing yourself during cornering.Without the proper routing holes in the seat back and thru the bottom of the seat for the submarine belt, they won't provide any real safety benefit.
Your car would have to be the prototype if I made one for the MS6. Not sure if there’s a market for them as much though. But I'm sure we could work something out.(potkettle lulz
A properly located belt setup will go a long way in holding you in place.on msf corksport is getting tired of people criticizing their new products so they want to team with someone to pay and produce their own idea then I guess corksport will market it and somehow split the profits.
Yea I want to get a set of racing seats because my legs and groin were so sore after mid ohio from me holding myself in place. I liked that I didn't have any effort in holding myself in the correct position in will's car. But I need to find seats that are still comfortable to dd in because idk how long I will be able to keep that dd I have.
