Jeans, what type of fabric did you use for your headliner? Was is foam backed?
headliner is just dyed... stock fabric dyed black haha
just a flannel material i bought at jo-ann fabrics
i thought about the headliner but felt it would be too mcuh
How did you guys go about wrapping these parts? I really want to wrap the door panels in the RX-7 in the same material my Sparco seats are in. Need to ditch the 80's-themed fabric going on in there.
I'm looking forward to Saturday. Hopefully a few folks show up.
I'll be there, someone has to keep the Monkey A$$ Dockers Wrinkle Free, Stain Defender in line.........
bah! Front tires are hitting the spring perches on the coilovers. Used the strut mounts and was able to stop contact at +0.5 deg of camber (doesn't make sense to me as the entire wheel/strut combo moves together when you adjust camber via strut mount). So i have a plan to alleviate this - camber bolts! Since camber bolts adjust camber from the bottom of the strut i can use those to dial in some positive camber to get the tire away from the strut and then use the strut mount to dial the negative camber back in. Does this make sense?
Haha I'm here freaking out because I'm running around with +0.5 degrees of camber on the front and -3 in the rear! The front tires are now DANGEROUSly close to the front fender (when I get this resolved, I'll show everyone what I mean - I'm at the very limit for tire/wheel width in the front).makes sense to me... Haha
