The Ohio Auto-X and Track Event chat thread
A question. Would it be a good idea for me to use stock (16") P5 wheels with nearly trashed potenza tires on the back and yoko parada 17" on the front? Would this set up help a little with rotation? The car pushed like a mofo at the LCC auto cross.
Ideally you would want to have a larget RSB. If you want the car to rotate more you can over inflate the rear tires, if you don't want to do suspension upgrades. I would use the Parada's on the front.
My thought is it might help the car rotate a little bit with a narrower tire and track width on the rear. You know what's up with the RSB upgrade and there is no way for me to have it done for toledo.
This. That was my issue on the MSM. Remember the EKG dyno? Wires the whole time.
I knew my wires were gone when it stared sputtering, they looked fine when I replaced them. They were only an issue in the high rpms
I guess I might have to look into it. It only does it at WOT while under a full load 9 psi around 5k rpms so I guess it might be the issue.
That's exactly what mine was doing. Anything over 8psi, and relatively decent load, and 5k-ish. Check yo wires fool!
Possibly but I have one scheduled for either Sept. 9th or Oct. 16th to be my last event of the year. School starting is going to kill my funds. Whoo for the first day
Apparently my driving was so bad they put me in the novice group... :( Haha
Just because they put you in that group doesn't really mean anything, just that you are in contention to win the novice points standongs at the end of the year. You will still have your normal points and standings within your car class. Probably was saved in your profile when you registered for the event. They just don't throw you in there ;)
That was pretty funny. We should all put funny color names next time.
