PrinceValorum
- 95 626 FS, 89 Toyota Derux 4x4
I was almost going to ask if a gearset like that is affordable, but then I remembered whose car it is...
How hard was it to wire up the Racepak? I have been looking at getting one for my car..and I assume that is a PAR gearset?
Brain, do you track the car? If so, do you have any track video or anything we can see the P5 at it's full potential?
ps- I have the same stereo.![]()
Yes If you look in the Garage under "Most Money Spent"
I have only entered 19 Mods and that totals $24,000
The Next down has 77 Mods at $19,000
So you are correct, the gears are Effen $$$$
Hey thats me- I underpriced everything............LOL, but yes I saw the price on that gearset/ EMS and damn.....I wish I had the $. Atleast I am switching to the Haltech this winter![]()
I agree, the GoPro's don't seem to show speed/ acceleration well for the car they are on.
BTW it's been along time Brian, how have things been?
Rob
Are you using the CAN BUS setup or is there literally just one wire that "ouputs all" from the PS1000? I thought about picking one up for a while but I settled on the Sprint RE (basically a Sprint 500 for the rotary) and didn't want to mess with it all. I haven't identified a good way to measure roadspeed yet anyway...One wire to the Haltech runs the entire show..
You could probably not just hook up the IQ3, it is designed to operate off of a CAN BUS, like a network or LAN in the car. It is connected directly to my ECU, but that ECU is connected to everything in the car so it's a bit more complicated than that. I was just saying that if you already had a Haltech E8, E12, PS1000, PS2000 or Sprint500, it is literally One wire to add the IQ3. I have been running the GT28 Well beyond it's limits. I can get one or two pulls out of 25 - 27 PSI but then the EGT is way too high from the heat generated by the back pressure of the turbo. Basically, going from 15 to 20 Psi, there is a huge difference, but going from 20 - 25 or 27, there is much less HP being made because the turbo is literally starving the motor. This Fall/Winter the turbo is being replaced with a Perfectly suited GT-3071 .63, It will satisfy up to 500 HP which the GT-28rs will never be able to do. I am expecting to be able to breach 400 WHP at 25 PSI. Everything is built to survive that, and I need as much torque as possible to get from 250 - 300 Km/h quickly so I can throw down some speed in TEXAS!Gotcha. Sounds easy enough. I imagine I could hook it up in a similar manner as I do my laptop to my MS3/MS3x.
What kind of power are you making in that?
Are you using the CAN BUS setup or is there literally just one wire that "ouputs all" from the PS1000? I thought about picking one up for a while but I settled on the Sprint RE (basically a Sprint 500 for the rotary) and didn't want to mess with it all. I haven't identified a good way to measure road speed yet anyway...
