The final word on Halogen bulbs
I think MSP and MP uses same kit...9000 something...
P5's have different headlight assemblies from regular protege and MSP.
MP3, MP, MSP have same bulb types and P5 are using H7 as a low beam
dual beam kit sounds expensive :)
What do you mean? If you have a P5, you need a 4500K Single Beam HID Kit. If you have a Protege, you need a Dual Beam Kit. Both are under the Lighting Products->HID Conversion Kits links.
Please email me if you have additional questions, thanks!
D'oh! Sorry, I was looking under just Halogen, not HID kits .... sorry! Does the H3 foglight kit work with the fogs in the MSP?
Yup. The Proege and P5 both use H3 for fogs. I do not know if there is a lot of room in there or not, but if not, you can get the H3 fog kit which has a much smaller HID Capsule.
Don't forget the StonGard!!
That 3M stoneguard stuff (If thats the stuff you're talking about) looks like it rocks, I just have to find someone near me (NJ) to install it, ... as I'm sure i'd screw it up if i did it myself.
Thanks for all the light info though!
I don't think it's that hard to install it.
you just need proper equipment. :)
like alcohol(70%)+ water(%30) and mix those two
apply to the lights
wash it and dry it then apply 3M stone guard gently...
Actually, the light protection kits you could easily do yourself. Quite different from their Paint Protection Kits... these are 80mil (VERY thick), but hardly noticeable since they go right up to the edges.
The install procedure is rather simple. You clean your headlamp like Bijou mentioned, then turn on your headlights until the front lens is warm (don't get fingerprints on), then work from the center out. They provide you w/ a squeege. Again be sure not to touch the sticky side or you'll get finger prints on it.
