so what's the best way of doing this if you don't have the 3 bolt outlet flange? just put a fitting on the closest hardpiping?The nozzle on the outlet adapter is so I can run a pure boost source to my wastegate. It will allow me to get faster response on my wastegate since my line going to it will be less then 6" long. It will also help me prolong the life of the wastegate since the diaphragm isn't being pulled/pushed on it will only be pushed on with the boost only source.
cool thanks for the info. do you have more pictures of your car?
i'll update this thread after my car is completely road legal and i'm able to drive it more. i think i've driven the car a total of 25 miles so far.
check your charge pipes.
Edit: for oil that is.
