Is there anything I should watch out for? I got my replacement gasket kit from TurboXS today so I'd like to throw this on sometime in the next few nights. Thanks
come to think of it, you may have to remove the brace that is under there. i dont think you can remove the cat without removing that brace. but i am sure you are already aware of that. if not, again its just unbolt the brace, unbolt your cat, install the test pipe, bolt up, replace brace, bolt up, test drive, check for leaks, VOILA!
Yes,Im pretty sure you have to remove the brace.Its a simple mod to do tho.You may also want to put some anti seize on your race pipe bolts since they tend to rust easy.
