Tear down help
melicha8
When I was taking apart my car the thing that stopped me was removing the axle from the hub. I did everything I thought would work. I used wd40 along with some pullers and I also used a crowe bar. So is there anything anyone did to get these off. Oh yeah I was able to remove the large bolt so they could come out. So help me out...how did you that have done this do this?
Look at the end of your axle. There should be a small dimple in the end of it. You use an air hammer with a round tip in that dimple and it will break it loose. I run across this with Volvo axles all the time.
No I got that bolt off of the axle, we are talking about the large diameter bolt. The problem was getting the axle out of the front suspension setup.
ended up taking it to a shop? How do you like it now with a lighter flywheel, and better holding clutch. I was thinking about getting the ACT and lightened flywheel combo. You think its worth it and which clutch would you recommend?
Mike
They come with bearing centering tool, throw-out bearing, pressure plate and disk. at least that is what mine came with
