ok, since we have a special verison of the splitsecond afc(psc1-020), it includes 02 sensor hook up. as of my understanding, the 02 sensor hook up is for the output b mode feature that is included in the software that comes with the afc.
you have control of output b mode. when you want output b to turn "on", it sends a signal to the o2 sensors, and it tells the car to go into open loop. it does not take complete control but it does a very good job switching to open loop.
so my original problem was i could not control open and closed switching back and forth each other, and i was only able to tune open loop because the pcm level to tune closed loop position is to strong.
so basically my map starts at -3 hg. i set output b mode to over pressure, and i set the pressure to -2.99. so in other words, everytime my car goes under -2.99 hg, my car goes into open loop. (you can also choose over rpm, or both, but i thought it was best to set it to over pressure).
with this setting, everytime i stomp on the gas pedal my car goes into open loop. since my hole rpm range is in open loop, i am able to gradually lean out the ratios between 12.5 to 13.5 afr all the way up to redline.
if you look at the attachment i made earlier and look at my map it will make much more sense.
basically it is the same thing as the superstock map, but in the NA cells and settings.
i hope i explained my self well. and this actually works very well! ken if you tried it, i think you would be impressed!
