the forge valve is kind of annoying. if I had an extra 200 bucks int he bank that I didn't know what to do with, I'd get the synapse for the heck of it.
lol thats the spirit (boobs)
Sorry for my ignorance.....but what's "IMO"? So the Forge is a better fit (pressumably an easier install) and half the price ($159 on mazdaspeedstore.com) with very similar performance increases over stock. Thanks for your candor, perhaps I'll avoid the hype and try the Forge.
The Forge is known not to hold as much boost as the HKS or the Synapse valve due to their design; push vs. pull.
Forge is a great valve if you are on a tight budget...but the convenience of the HKS and synapse are well worth the extra $$$; no messing around with shims, springs, or adjustments.
Just my 0.02 cents...
To be fair I did have to spend a few min tuning my Synapse to get the performance i was looking for ....
Hmm... OK then, my HKS was simply bolt-on and go... (lol2)
I hear thats a good valve!
The synapse is supposed to be a bolt and go too, but i didnt feel like it was as fast reacting as it was supposed to be so i took some pre-load off and BIG difference it took like 3 min lol ....
BTW....at a $30 price difference (essentially the same price as far as I'm concerned)........performace and ease of install would be the two most important factors.
I really like the idea of a quick and easy install/un-install incase I want or need to go back to stock. I'd really rather not have to cut the .8 inches off the rec house for that reason. Anyone else have an opinion on the HKS vs. the Forge?
For the speed 3 in the stock flange location you do not need to trim the recirc tube(i know they say so but its works with out doing it) ...remember if you have the Cobb SRI you will need that .8 they tell you to trim..
$30 between which 2
This is based on having a cold air intake? Also, do you have to rotate the recirc tube to make it fit?
Between the HKS and the Forge. BTW......did you experience driveability issues with the Forge?
really want to get an opinion on the turbo xs seems like a good buy. I don't really understand the hybrid concept though? But can anyone enlighten me.
Is there any fitment problem (like cutting the recirc hose) with CP-E CAI with synapse BOV?
the CPe works perfectly with the stock setup, so I would assume that if cutting is required with stock parts, it will be with the CPe intake.
