rubber gaskets? where are these rubber gaskets? I was thinking of switching over to mobil 1 from castrol syntec high mileage.
So at 67k, I shouldn't have any problems changing over to synthetic when conventional oil has been used up to this point?
Yeah i just switched to Castrol Full synthic at 16000KMs on my 2003 pro5 and i would agree it does feel smoother, is there any syn tranny fluid?
Yes, Redline make very good Synth. tranny fluid, can't find it everywhere though.(burnout)
i used mobil 1 full syn about 1k ago. I haven't really noticed any differences. although i feel better about having a full syn in there. plus now when i go 4-6k without a change i know that i'll be ok. isn't there a different oil filter or something from the 6 that the P5 can use to up the oil capacity a lot?
I just bought a Protege with 70k. The p.o. was using Quaker State synthetic and said he did his own oil changes. On a cold startup, (30/40 degrees) I was getting an alarming metallic knocking noise for a few seconds, like it wasn't getting oil. I asked a mechanic about it and he mentioned that the factory oil filters have a check valve in them to prevent taking up oil at startup, (something like that). I had them change it with a factory filter and haven't noticed the problem since, knock on wood. Anyone else experience this?
They put a 5w20 syn-blend in, I don't know what kind. But I may go back to full synthetic.
