inverted25
 - 2014 Mazda CX-5 Sport AWD
I have a 2014 CX-5 with 145,000 miles. I noticed the tires were getting wore unevenly with the inside of the tires wearing down much faster than the outside. I decided to replace the front strut/coil assemblies and the rear shocks. Once I got working on the car I ended up having to replace the inner and outer tie rods on the front, the sway bar links front and back and the front lower control arms. I had two sway bar links that had broken off and were just hanging by one side. The ball joint on the passenger front had excess play in it so I replaced both lower control arms.
I am about to change the spark plugs and do a drain and fill on the transmission with a filter replacement. Is there anything else that I should be addressing at these miles.
The only things done besides normal maintenance on this car has been replacing the rear brake calipers due to a locked up caliper around 90,000 miles. I also had to replace a switch in the shifter control column awhile back.
