Sunroof won't always close
JRH13
Mazda, Protege EX
The sunroof on my 03 Protege has been acting up. It seems to close fine when the temperature is warm or the sun is shining, but if it cools off or a chilly night hits, it won't close. It also seems to squeek a bit. Any advice? Thanks
Sounds like it needs lubrication. I'm not sure how to go about doing that, you can try seeing if anything is accessible to lubricate. But it's more likely that to do it properly you have to remove the headliner.
