Fisticuff697 said:Hey guys. Im actually one of those overpaid mazda dealership techs. The only problem I have ever seen with random missfire from the bullet proof protege is problems with the egr, leaking regulator(make sure you check this), spark plugs( need to be replaced every 30k or it will take out the two coil pack) and every once in a while a leaking intake manifold gasket.ANY vacum leaks can cause missfires. ANY rich conditions can cause missfires, the computer can only see what SHOULD be there so anything that is leaking shouldnt be there and he wont see it. Lately we just got a recall for the butterfly screws....seems under a certain vin the little bastards will come loose and fly into your engine. good times. Anyways they are copper and dont cause much damage but closing the tip on the spark plug. As for fuel pumps they hardly go out. Listen do the smart thing, check fuel pressure with a gauge., if it is right ,bam, fuel is good. Check spark and ohm check the coils. If it is good, bam ,spark good. Ohm check the injectors and you guessed it, bam, if they are good your golden. give them a good bg cleaning and replace spark plugs. Also if you havent replaced your timing belt at 60k do that as well. If you still got some kind of a missfire than i would say pcm problem or internal short/open in wiring to the drivers for fuel injectors or driver for the primary side or the coil windings. Im ASE certified, mazda certified, College graduate. Just trying to help.
he has another thread with his problem. i linked him here to read on what everyone went through for a solution.Diehonda said:Just ask the question. This thread is too many pages to read it all. It has been repeated enough times, just go for it.
