Well I made it back from Topeka in one piece. I've been having fun today burning the last of the 100 octane out of the gas tank. I'll probably take a break from working on the Pro5 for a little while so I can finish up and start a few other projects. I'll have it back in the garage this winter at some point for a few updates. It's going to need at least 1.5 degrees more rear camber, 15X8 inch wheels, and a little more HP.
Rear camber is a little wierd. The way the AWR struts are set up I can only get about -1 degree even with the rear camber plates modified. I'm going to go in and cut a little more on them, but the results will be minimal. I'm going to have to look elsewhere to gain what I need. I'm going to get 1 inch shorter springs in the rear so I can raise the lower perches up and out of the way of my street tires. That will hopefully give me enough room to use some camber bolts on the rear spindles. Right now there is not enough clearence between the wheels and the strut/spring perches to change the angle between the spindle and the strut. With more rear camber I can transition and turn significantly faster.
I finished 16th out of 24 drivers in Topeka. I was hoping for a little better, but it was a finish that recieved praise from a lot of the FSP veterans there. Will Kalman definitely showed that the 1st Gen Protege/Escort chassis is competitive with his trophy finish and he wasn't even running an LSD or any power mods. I had the most HP of all the FSP cars there by far, but I was also the heaviest by at least 200lbs. I'm looking forward to building a FSP 1st Gen Protege to compete, but I'm not done with the Pro5 yet. I was the only competing station wagon in Topeka and that's just too funny to give up on yet. I plan on scaring even more people next year.
