D DRKNYTE Member : 2008 MAZDASPEED 3 (BLACK MICA) Aug 9, 2008 #1 Can anyone provide the stock wheel info: Bolt Pattern - Hub Bore - Lug-nut pitch - Width - Diamiter - 18" Offset - Weight - Tire size - 215/45/18 Thank you! Maybe make it a sticky? Maybe?
D DRKNYTE Member : 2008 MAZDASPEED 3 (BLACK MICA) Aug 10, 2008 #4 Thanks guys for the info... 24lbs is a lot!
B broncoblitz Member Aug 10, 2008 #5 Bolt Pattern - 5-114.3 Hub Bore - 67.1 Lug-nut pitch - 1.5 Width - 7" Diamiter - 18" Offset - 52.5 Weight - 24lbs Tire size - 215/45/18
