Stock P5 bumper
Hey guys or girls,
I was just wandering how hard it is to remove the front bumper of my P5. I just purchased the Wings West bumper and should be in this week sometime. It is already painted so all I need to do is put it on. I just need to know if I need certain tools and all that good stuff. If anyone has a "How to" send it my way
Brian
it isnt bad at all. i took mine off in the MSP in maybe an hour, but that was because it was the first time doing it. now i could do it in like 1/4 of the time. i dont have a how to tho, but im pretty sure someone else does. this is all from memory btw, so it might be wrong....theres just like 3 of those snap screws in each wheel well, then you pull the well away and there are 2 screws you take out (on each side). then theres a screw underneath on each side and just some miscellaneous screw-age on the underside. then it just pulls out.
all you need is a screwdriver and a 10mm (if i recall correctly)socket wrench
Thanx guys,
I really appreciate this alot. Now all I need is for my bumper to get here which should be by Wednesday at the latest
Brian
You can also check out fmprotege.com and look at their install manual. One of the things required is removing the bumper and they give you instructions with a diagram displaying where the bolts are.
