it should just click once... it sounds like your's is all messed up. If its brand new then just send it back to FM and theyll test and send you a new one. There is no need for you to soder really, simple T clamps should work fine. Also your injectors maybe bad... they dont tend to like 100psi... it alters the spray pattern and they can start to stick. Also O2 sensor has nothing to do with it... my 2nd one is none exsistent.
