MSPM1cheLe
DRVRMOD
- 2010 BMW 135i
Okay so I've tried 2 brand new walboro 255 pumps and have ran into the same issue:
The car takes 5-8 turn overs before it starts.
I think it is flooding with too much gas, causing the motor/ecu to have to burn the fuel before it can start.
The other idea (which I thought it was at first) was I thought it was not getting ENOUGH fuel being as when you turn our cars into the "ACC/ON" position the fuel pump does not turn on. Essentially it only turns on when you begin cranking.
I am going to attempt to replace the fuel filter with an actual stock one (instead of the autozone version) in case the larger filter that they gave me is causing more fuel to be absorbed/picked up.
Anyway, has anyone else came across this issue with the walboro?
