Stalling 95 626
seadal
I have a 95 626 4cyl automatic and it stalls when I start it. Not everytime. I have replaced the cap, rotor, spark plugs, wires, fuel filter, and the PCV valve. I pulled the valve cover off and checked the timing belt to see if it was worn and it looks new. Also looked at the cam shaft lobes and there is no wear. The only other thing I can think of is the EGR valve which costs almost $300 at Auto Zone. I also messed with the timing to see if that was the problem. I cant figure it out, anyone got any ideas?
Also when I get up to a good speed and the auto tranny changes gears I dive to the right. Any help would be great.
How many miles? Did you replace the air filter? I'm trying to remember if that car has a MAF. These good bad overtime.
I know with BMWs that have similar issue its the either the cold start valve or idle speed regulator.
The car has 135,000 miles on it. I did replace the air filter, and it does have a MAF. I got a hold of a used EGR valve, I am going to try to replace it tomorrow and see if I have any luck.
